Home > My Range Rover Sport > Help
Willis1987
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Help
i have a 2012 range rover sport HSE sdv6. When accelerating it sounds like i can hear an air leak sound from under the bonnet after about 1300rpm and goes at around 2500rpm which suggests a boost leak however no loss of power. seems to be louder when i accelerate hard. when im gentle on throttle doesnt seem to be as loud. Any ideas where to look? Or anyone else had this?
Thanks in advance Matt
Post #620909 Thu Jan 13 2022 5:39pm
karlos01
could possibly be a leaking manifold gasket
Post #620914 Thu Jan 13 2022 7:04pm
Willis1987
Hi
karlos01 thanks for your reply if it was manifold gasket would it not be constant rather than easing off at higher RPM
Thanks
Post #620917 Thu Jan 13 2022 7:50pm
karlos01
got a leaking manifold gasket on mine it makes a noise when under load but once it up the revs it quietens down and ist so loud that's why I asked if it might be that
Post #620924 Thu Jan 13 2022 9:16pm
MREXIANI
Italy 2012 Range Rover Sport 3.0 TDV6 HSE Lux Orkney Grey
Hi Willis
My opinion from (same?) experience
Two issues. the first and most important is the broken intake manifold ; that's sure
Second, more subtle, due to the fact that it's very difficult (impossible) for this failure, so evident to ear , does not exploit an anomaly of recovery mode. This suggests a mod to the ECU (rechip) . A common way which is done to overcome resticted performance mode eg recovery mode.
Good luck
Alex
Post #620927 Thu Jan 13 2022 10:06pm
Willis1987
Hi Alex
I looked at them lastnight it looks like passenger side has a new manifold but drivers side is an old one so might look at changing that as a matter of cause. A company i used to work for have an ultra sonic leak detector so might look over manifold see if i can pick up air movement / leak.
Thanks
Post #620939 Fri Jan 14 2022 11:37am
Site Copyright © 2005-2022 Futuranet Ltd & Martin Lewis
