![]() | Home > General > FBH is mine functioning ? |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 ![]() ![]() ![]() |
Vehicle is a 2010 3.0 TDV6, I've searched the subject on here but can't find the answer.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Do you have the option to set the timer via the infotainment screen? The other option is a plipper that allows an instant start up of the FBH. |
Never noticed this, had the vehicle almost 3 years Peachy I've never seen the on screen option for the FBH, can you direct me to where that should be, no remote either ![]() |
If I remember it’s located under the extra functions icon & then timed climate - is it definitely fitted to the RRS |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
The FBH doesn't always smoke - indeed I'd say it shouldn't smoke if running correctly. Mine works and doesn't smoke and there's little, if any, smell either. A bit of condensation can be seen in the FBH exhaust stream if the vehicle is left running on a cold morning just after starting up. Best way to see if it's working is to lift the bonnet a minute or so after starting the engine on a cold (6deg C or less) morning. You'll hear it running. Alternatively, a minute after turning on the engine on a cold morning, put your hand below the small pipe sticking down in the near side wheel arch. You'll feel the exhaust gases. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Assuming this is the FBH then yes I have one ![]() ![]() Can't find anything in the info settings ![]() |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
see at 8 mins
Thanks Andy, very helpful. Having watched the video, I have heard it running in the past and noticed the snowflake on the dash, it however doesn't have the option for timed settings, possibly something that can be done via a software update |
The snow flake just indicates it’s 4C of lower and to drive carefully as roads maybe icy |
Ye of course, next time it's below 4 I'll make a point of listening for it kicking in |
https://www.gap-diagnostic.com/avada_faq/h...park-heat/
Sadly not ![]() |
Thanks for the info but I'm a technofobe when it comes to software, wouldn't know where to start ![]() |
