![]() | Home > Technical > steering wheel lights |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5144
it will be the clock spring I expect.
| BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410
+1 with Andy K. Highly probable it's the clock spring. Not something I'd try to replace but others here have done so successfully. Barrie.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
Easy enough to replace clock spring, just make sure to disconnect battery first and leave for awhile to ensure any residual voltage etc. to dissipate. Can buy tool to release air bag for few quid or a bent metal coat hanger will suffice.
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309
is it the sme as removing a p38 steering wheel it was 4 the torx bolts hold the irbag in place |
No
ah I best swat up on it then 😆
You need a tool similar to this.
thanks col for I'll watch the vid brother inlaw has the airbag tool you posted |
| All times are GMT |
