Home > Faults & Fixes > rrs steering gone heavy
bricky0
hi all
i have a 2005 2.7 tdv6 rrs my steering has gone slightly heavy when turning the steering doe not re centre itself no visable leaks i was thinking pump,
anyone else had a problem like this before
any help or advice will greatly welcome Thumbs Up Thumbs Up
Post #620569 Wed Jan 05 2022 8:02am
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi check the link shaft from the steering column to the rack there is a joint if I’m correct that starts to seize on small Uv type joint.Normally best if it is that is to get new one fitted think if Independent LR Garage price fitted about £250
Post #620575 Wed Jan 05 2022 11:05am
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
is it heavy or "lumpy"?
Mine was lumpy and replacing the lower steering column. As iomegas says fixed it.
Replacement part is about 100, get the two bolts. It will take you about 2hrs to do yourself.
https://www.advancedfactors.co.uk/lr071146...7463-p.asp Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Sadly gone - 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #620579 Wed Jan 05 2022 12:47pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
I had the same problem on my 2005 a couple of years ago. Took it to my mechanic who lubed all the UJs. No problem since. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #620580 Wed Jan 05 2022 1:02pm
bricky0
many thanks guys lube up lower uj problem for now fixed
looking into getting replaced Thumbs Up Thumbs Up
Post #620631 Fri Jan 07 2022 5:57am
BJH1959
Good news! Barrie.
Post #620655 Fri Jan 07 2022 8:11pm
