![]() | Home > General (L494) > Stolen |
Nveeate Member Since: 10 Aug 2021 Location: Scotland Posts: 28 ![]() ![]() ![]() |
Sorry to hear that. At least they didn’t break in for keys I suppose. Hopefully the insurers will get you in a replacement soon - are you going to get the same again? |
Kenniff Member Since: 04 Feb 2021 Location: London Posts: 55 ![]() ![]() |
That’s a good question!
Sorry to hear about your rrs,,is their any cctv in the area which will help how they took it if keys were in faraday pouch,also I thought they’d updated the new keys so they can’t be scanned.Have you checked your faraday pouch as the only seem to last for so long & I recommend if you get a replacement vehicle get a disk lock,that’s what I now have & if they see that they probably go on to the next car. Andy.
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 549 ![]() |
I was of the understanding that a 21 MY could not be stolen by rebroadcasting…
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 390 ![]() ![]() |
I reckon your biggest issue will be getting a new car without a very long wait.
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 ![]() |
Did you have keyless entry switched on? regardless if they are in pouches, most pouches are not big enough to fit key fob and attached ironmongery etc.
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 352 ![]() ![]() |
Get a Ghost fitted on next car and a independant tracker as scumbags know where the factory trackers are. Only costs around £650 for both and worth every penny if you consider the inconvenience and stress to sort out RRS HSE DYNAMIC 2015 ODESSEY RED |
I think you are exactly right. current: RRS HST P400 engine ( 2021) Hakuba silver |
Key pouches fit easily and were working fine. I’d only done 6500 miles. Keyless was switched on (which I won’t be doing again). Cat 5 notification worked - the car told me it had been stolen less than 2 minutes after it was taken. Car spotted on cctv at the end of the road but no one identified.
Nightmae for you RRS HSE DYNAMIC 2015 ODESSEY RED |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9083 ![]() ![]() ![]() |
I'd have used 999 or did it take 15 minutes to get through on that? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Stupidly, first thing i did was ring JLR, to confirm it was a theft. They told me to use 101 to report it which again with hindsight might not have been the best decision. current: RRS HST P400 engine ( 2021) Hakuba silver |
For future info, as suspected a 21MY cannot currently be attacked by rebroadcasting. However it is possible to code it a new emergency key to recover the vehicle but not open vehicle doors..
louischristie8 Member Since: 05 Jun 2012 Location: london Posts: 61 ![]() ![]() |
Nope, they just pull the lock cover off the drivers door and use a lock pick to unlock the car. They did it to mine then used an emergency start. Whole things takes less than 2 mins |
