Home > Technical > Turbo Hose advise 2.7tdv6
savi18
New Zealand
Lost power and loads black from rear of car towing 2 ton caravan over the hills here in NZ, opened bonnet and top Turbo hose split which is a common problem I believe, had the car tuned 6 weeks ago with 30% increase in power which I think may have caused weak hose to split with increased boast pressure, is it best to for new genuine hose or to fit silicone hose as cannot source silicon turbo hose in NZ, how many have had engine tuned and been ok with standard hose fitted.
Post #620453 Mon Jan 03 2022 7:27am
Stevepd
Well if you can’t source silicon house perhaps your choice has been chosen for you. Also if the original has lasted this long…… 2006 2.7 TDV6 HSE in Cairns Blue.
Post #620457 Mon Jan 03 2022 8:57am
savi18
New Zealand
Thanks for the reply Steve, what a want to know is if i fit standard Turbo hose and having the increase in Turbo boost will the standard hose cope with increase in pressure, cheers
Post #620519 Tue Jan 04 2022 4:52am
garrycol
Australia
My car now covered 202,000km and is 14 years old with all standard hoses, never replaced. Had a BAS map done in about 2012 when the car had 60,000km - no issues at all. Reports of turbo hose splits are pretty common and does not correlate with remaps.
Just buy a standard hose if your preferred option is not available. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #620520 Tue Jan 04 2022 5:12am
