Home > Maintenance & Modifications > Anyone know where this hose goes please?
Gas-guzzler
United Kingdom 2007 Range Rover Sport TDV8 Sumatra Black
Hi all,
Was underneath my 07 RRS yesterday replacing the fuel tank cradle and noticed this hose roaming wild and free. It’s above and next to the rear diff and the rear diff appears to have a nipple on top which I suspect may be
the breather it is supposed to be attached to? Any advice greatly received. Photos aren’t great can take more if needed?
Thanks.
Post #620307 Tue Dec 28 2021 3:25pm
It does appear to be the rear diff breather pipe. It should run up alongside the fuel filler tube and terminate up near the fuel filler flap area.
It would be worth blowing it through to make sure it isn't blocked - it might have come off because of that, or it's been removed by a spanner monkey and not reconnected. 2012 SDV6 - it's missing a couple of cylinders
Post #620337 Thu Dec 30 2021 11:54am
Look like the rubber sleeve that fits over the nipple is split and perished which could also account for it coming off, the actual nipple doesn't look to healthy either.
Post #620340 Thu Dec 30 2021 12:19pm
Gas-guzzler
Thanks guys. All makes sense. I shall clean it all up and improvise with a new bit of rubber hosing. Appreciate your input.
Post #620357 Fri Dec 31 2021 12:58am
DrDeAtH
Might be wise to change the diff oil too. Water may have got in where the breather hose fell off.
Post #621046 Mon Jan 17 2022 10:08pm
