Home > General (L494) > Gearbox Fault followed by clunk then Terrain Response Specia
Candyroch
i am at my wits end with my car.
I’ve had my car seen to be an independent specialist but everytime it has went in with its sadly came back with more issues.
At the moment my car displays ‘gearbox fault’ then a clunk noise from beneath the body.
Prior to the car going to the specialist it didn’t show any visible issue on the dash. But the clunk would happen when I switched the engine off.
The specialist said he attempted to calibrate the TCM when he heard the clunk, but since that software update I now have a dash error and no use of my terrain response either.
As a side note, I have a new main battery, new auxiliary battery and alternator all done in the last 18 months. Since the alternator has been done my passenger airbag light has remained on too.
Any help, guidance or support is greatly appreciated or I fear it’s getting traded in
Post #620209 Thu Dec 23 2021 10:32am
Disco_Mikey
What codes are stored?
Post #620210 Thu Dec 23 2021 10:37am
It is quite likely that his attempt to 'calibrate' the TCM resulted in corrupted/mismatched software versions between the gearbox and the ECU, so now the car doesn't know what's going on.
Time to find another indie workshop? --
Post #620211 Thu Dec 23 2021 10:47am
Lindab
As above, find another garage who knows what they are doing. Someone will soon be on to point you in the right direction. I use Disco Mikey, maybe a bit far for you to go Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #620215 Thu Dec 23 2021 11:07am
Candyroch
Sadly I don’t know the code that was displayed and I don’t have an ID tool to check.
The possible issue with mixed software would be a blessing.
Disco mikey where are you? I have recorded a video if it would help at all.
Post #620222 Thu Dec 23 2021 2:23pm
Disco_Mikey
Dundee
A video is unlikely to help. a fault code will give us an insight into the problem Thumbs Up
Post #620223 Thu Dec 23 2021 2:55pm
Candyroch
I’ve asked a guy I know from a local garage if he can read the codes for me and I’ll get back to you. Can you let me know your working hours too please mate and all going well I’ll try get up to see you.
Appreciate your responses.
Post #620224 Thu Dec 23 2021 3:16pm
Candyroch
Hi everyone apologies for the delay but I had to resort to the AA to get the code.
The fault was logged as ‘clutch adaptation calibration fault’ PO80A
I hope that helps?
Post #620540 Tue Jan 04 2022 2:41pm
As suggested someone screwed up the calibration or calibrated the wrong Module, do as suggested and take it to someone who knows what they are doing i.e Disco Mikey.
Post #620555 Tue Jan 04 2022 9:46pm
Candyroch
Hi Col,
Thank you so much. I’ve sent Mikey a message.
Post #620557 Tue Jan 04 2022 10:10pm
Candyroch
Hi guys I just wanted to ask if anybody had any other specialists they could recommend?
I tried to get in touch with Mikey both here and via his advertised numbers leaving messages with no luck. The gentleman from the AA recommended Monarch in Dalmarnock but I would appreciate if anyone could let me know their experience or offer another place to go to get this sorted.
Many thanks
Post #620840 Tue Jan 11 2022 8:29pm
Stevepd
Keep pursuing DM, or you may expose yourself to more messing about. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #620854 Wed Jan 12 2022 12:16pm
