Home > General (L494) > Brake discs @ pads l494 2016
Coedlan
I need to order on-line, Is there a way of ensuring I end up with the correct parts for front and rear brake discs and pads
I need to change pads as a minimum, but may as well change discs at the same time. (44k miles)
When I bought my l494 back in 2016, I specified the bigger brake option on the front, they are red Brembo, but that name doesn’t seem to uniquely identify the brakes for my car?
Would topix tell me my exact spec? (I can’t access it though)
Any clues on diameters, part numbers etc would be appreciated 2016 L494 HSE
Post #620202 Wed Dec 22 2021 9:50pm
timhum
I'm not sure that you are correct that the Brembo option gave bigger brakes. I bought an HSE in 2017 and investigated this option and to me it appears to only offer a red caliper branded Brembo. I checked through the specifications at the time and the brake discs were the same size as standard. I appreciate that this doesn't directly help you but it may be that the standard pads are what you want.
Tim Tim
RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame..
Post #620206 Thu Dec 23 2021 10:14am
Tyrefitter
I’ve just thrown a full set of discs in scrap as I upgraded mine to these & they were a reasonable price.
 Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #620208 Thu Dec 23 2021 10:31am
Andy, what brand & spec did you go for?
And do they provide better braking power?
thanks --
Post #620212 Thu Dec 23 2021 10:49am
SC247
I purchased these I have the Brembo brakes and the front disc are bigger 380mm against 365mm I think
https://www.ebay.co.uk/itm/254592861379?ss...2749.l2649
https://www.ebay.co.uk/itm/254592940071?ss...2749.l2649
Post #620213 Thu Dec 23 2021 11:00am
Kevin-t
Link to purchase please Bow down Bow down Bow down
Had drilled and grooved on my old disco 3 for years, they never made any difference to the braking, however No way near as much dust on the wheels.
Will be looking for these on my sport when the time comes Thumbs Up
Post #620214 Thu Dec 23 2021 11:00am
knwatkins
They look like the Britpart ones...
https://www.britpart.com/parts/performance...ritpart?f=|35 Kev
Post #620218 Thu Dec 23 2021 12:02pm
Coedlan
Tim
In 2015, when I specced the car, on the front, the bigger red callipers Tyrefitter shows in his pics was an upgrade, think they were bigger diameter, 380mm discs. I have seen newer cars with what look size-wise to be the same, just not painted red. Maybe they standardised on these bigger front brakes after my16. 2016 L494 HSE
Post #620221 Thu Dec 23 2021 2:20pm
Tyrefitter
I got the discs from a local indi LR specialist who got them from Britpart,,I also had Hawk ceramic low dust pad on the front which kept the wheels really clean. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #620227 Thu Dec 23 2021 5:55pm
Coedlan
Thanks, all for your responses - spoke with local motor factor who identified the correct disc and pad sizes via their systems.
I also had bad corrosion to both rear brake lines (6 years old) thanks Tyrefitter for your 2019 post concerning these. Seems like they are a well known weak point on these cars. Your photos helped me confirm with my motor factor the correct parts needed. Amazing how the main lines that these connect to are like new in comparison. Definitely something for owners to look at from as early as 4 years old.
 2016 L494 HSE
Post #620230 Thu Dec 23 2021 8:36pm
Tyrefitter
You can get those brake pipes from Advanced factors,,site sponsors on the forum.LR quoted me at the time they noticed mine we’re corroded when it went in for service,,£140 per side plus fitting,I got both sides from AF for around £90 posted for both sides & took me around 40-50 minutes to fit them both. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #620231 Thu Dec 23 2021 9:13pm
Coedlan
Hi, Tyrefitter got the brake lines and fitted them today, in the end, not as bad a job as it appeared.
I couldn’t find out what the brake line material was, I’d have liked something that was corrosion proof, but these are definitely bare steel, I don’t suppose they’re stainless tube??
Assuming they’re mild steel, what would you recommend to protect them for the future? Without any better idea, I’m thinking of smearing them in Waxoyl, though I keep seeing adverts for Lanoguard, any ideas? 2016 L494 HSE
Post #620355 Thu Dec 30 2021 10:32pm
Tyrefitter
Hi Coedlan,,wax oil,Lanogaurd,copper grease or similar should be fine,I covered mine in copper grease after fitting. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #620356 Thu Dec 30 2021 11:14pm
Grimble
Resurrecting an old thread, apologies.
Just passed my MOT today with the single advisory of Front Discs wearing. Not urgent, but something I will start investigating.
I have (as far as I know) completely standard as-built front brakes, so what would anybody recommend as a replacement and where would be a good place to go? A number of years ago I made the mistake of buying cheapest and the discs warped quite quickly (it was on an Audi) so as this is my first RRS I'd be keen on recommendations. I'm not after an upgrade or particular improvement, I'm quite happy with the stopping power I have got.
RRS is one of the early L494, built 2013 SDV6 HSE Dynamic RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #626084 Fri Aug 12 2022 12:03pm
3hcp
Try autodoc.co.uk
Takes a couple of weeks to arrive from Germany but quality parts, I went for brembo discs approx £120
for the front pair
I also upgraded to ebc yellowstuff pads from eBay which I’m impressed with 2015 RRS DIESEL HYBRID
Post #626095 Fri Aug 12 2022 9:37pm
