![]() | Home > General > Hockey Sticks..... |
But that wood finish loves bloody lovely. I know itโs yours but are you sure? 2006 2.7 TDV6 HSE in Cairns Blue. |
sam006 Member Since: 10 Sep 2011 Location: Kent Posts: 115 ![]() ![]() ![]() |
I think it ages the interior a bit. If wrapped can always revert back as well. Range Rover Sport HSE and for a bit of weekend fun a S1 Lotus Elise with a few track biased additions! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
I think you push them side ways, at the rear |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321 ![]() ![]() ![]() |
Agree, but each to their own. ๐๐ Steve 2005 2.7 TDV6 HSE, ongoing project. 1998 Volvo V70 R auto FWD, Back on the road again. 1999 BMW Z3 (owned from new) garage queen. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5120 ![]() ![]() ![]() |
If you want to remove the hockey sticks, you do have to remove the trim panel they are attached to first as they are held in with 5 screw which you get to from underneath. The trim panel is quite simple to remove though.
MarcMGD Member Since: 30 Nov 2020 Location: Essex Posts: 22 ![]() ![]() ![]() |
Col how do you get the panel out you have pictured? Mine is all cracked around the rotary gear selector part and want to either sand blast and gloss black or replace. How is it removed? |
This is for both 6 & 8 speed transmissions, will need to read through to find which parts you need, but to just remove the console it is basically the same steps on both, it's just that on the 6 speed the gear stick knob and gaiter needs removing first, would suggest anyone with the 6 speed stop the vehicle with transmission in neutral before removing gear stick as gives more room to lift console out without the gear stick shaft being in the way
Thanks all for the advice, waiting for the materials to be delivered Range Rover Sport HSE and for a bit of weekend fun a S1 Lotus Elise with a few track biased additions! |
