Home > Technical > No power at all tdv8 |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
I'm sure blanking the egr valves on the TDV8 is not normally the done thing,,, common place on the 2.7 but not so on the 3.6 as they don't normally cause any issues. Were the turbo's you fitted brand new or refurbished,, a few people tend to shy away from refurbished units. Have a search on here as lots of info on both subjects. 2010 RRS, TDV8
Sat Dec 04 2021 8:56pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
EGRs can be blanked on the 3.6 tdv8 no problem Visitor from fullfatrr.com
Sun Dec 05 2021 9:27am |
Geordieboy1205 Member Since: 04 Dec 2021 Location: Durhan Posts: 3 |
Yer they have been blanked off still have same problem with having no power at all as in its not boosting or anything people are saying the intakes but it has been smoke tested and nothing came out.
Sun Dec 05 2021 11:11am |
RobIpswichUK Member Since: 28 Feb 2018 Location: Ipswich Posts: 8 |
Did you ever get to the bottom of the issue? My RRS TDV8 has just started exactly the same symptoms and codes. |
Tue Sep 26 2023 10:22am |
