Home > General (L494) > L494 headlight conversion
Matt1981
England 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Evening
Hope your all well, does any one have a copy of the wiring diagram for the below it’s to convert the headlight loom from 2013-2018.
Regards
Matt
Post #619694 Thu Dec 02 2021 10:03pm
Red Arrow
Which loom is it and what company did you purchase it from ?
Are the headlights OE or copy units
Post #619698 Thu Dec 02 2021 11:58pm
Red Arrow
Loom
Post #619699 Thu Dec 02 2021 11:58pm
Matt1981
They are original headlights, I brought the loom 6 months ago from a company in Warrington all I have is the pic in the thread unfortunately
Post #619700 Fri Dec 03 2021 7:08am
Red Arrow
Does not look right to me but I may be wrong.
I had my lights converted so that they were plug and play to the cars original wiring .
The headlight main plug is totally different on the facelift lights .
I can send you the number of the chap who converted mine , I also had the sweeping indicator function added Thumbs Up
Drop me PM if you want to get them sorted
Post #619712 Fri Dec 03 2021 2:46pm
Terras14
Re: L494 headlight conversion
Matt1981 wrote:
Evening
Regards
Matt
Hi your conversion loom looks like the one from carsystem. This one can give you the full function but it is difficult to install and need some programming. The vendor you buy from should provide the instruction and help you programme once installed. Even if you can install, it cannot work without programming. Best bet is to find your vendor for the instruction.
Post #619767 Sun Dec 05 2021 12:35pm
Ryandsvr94
United Kingdom 2013 Range Rover Sport Supercharged Bali Blue
Have u got a number for who done your loom? I bought a similar loom and doesnt work
Post #630906 Fri Feb 17 2023 9:50pm
Red Arrow
Drop me a PM Thumbs Up
Post #630909 Fri Feb 17 2023 10:34pm
Ryandsvr94
Im new on here wont let me. Can you call or txt me 07946442544
Post #630918 Sat Feb 18 2023 12:25pm
Red Arrow
Number sent via text mate
Post #630921 Sat Feb 18 2023 1:18pm
zdmh100
Sweden
L494 conversion adapter
All,
interested in your feedback / knowledge here.
I have a MY16 SDV8, which was facelifted/SVR kit by the previous owner(s).
Front headlights were 3. pty, so AFS light came on whenever low beam was activated.
I have since sourced LR MID headlights and I purchased a L494 conversion adapter which I found on ebay.
https://www.ebay.co.uk/itm/165487864500
I hooked everything up to the new lamps according to the instructions, but still get the AFS when I turn on the low or high beams.
Has anyone any experience with this adapter (or seller)? I've tried to contact via ebay and email, but no response. Want to check all options before I return.
Second question; does anyone have a working solution/product for headlight upgrade? I have MY19 MID headlights on a MY16 car.
Thanks all.
edit: added photo of headlight sticker
Post #632540 Fri Apr 21 2023 1:59pm
zdmh100
Sweden
Update: returning the adapter I bought off ebay, will order the package from Carsystems, as I've seen others done. Seems to be the only way to get AFS working on a facelift/upgrade from MY16 to MY19 lights, as in my case.
https://carsystems.com.ua/product/range-ro...t-adapter/
Post #632699 Wed Apr 26 2023 8:25am
