Home > Technical > Old Subject - New post - Adaptive Headlight issue.
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
I have had this problem before, back in 2017 and bought 2nd hand, and now that one has a problem. Censored
The warning light for the AFS flashes intermittently. It can be cleared by my IID, then after a few miles comes back on. The lights are generally stuck and dont dance, but seem to be at the correct height.
But then sometimes they do dance!
The code below needs some interpretation from you folks, if you can? Bow down
HeadLight
B1D69-01 (AF) Right headlamp swivelling feedback sensor circuit - General failure information - general electrical failure
( on 11-04-2021 11:46:21 at 227156 km )
I did spend £81 replacing the Control Power Module to no avail, so before I spend around £500 on a Hella set from LRDirect, is there anything else I should be looking at.
OR, is it better just to buy the new one! Big Cry Big Cry Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #619706 Fri Dec 03 2021 10:44am
Sounds like the motor and sensor in one headlight has failed ?
Try plugging in the old headlight if you still have it. See if it goes.
Then you maybe able to open the headlight (using hair dryer )
And swap parts? Assuming they are good
Post #619710 Fri Dec 03 2021 1:11pm
MartinsTDV8
Sadly the old one had corroded electrics on the motor, hence why it failed that time Big Cry Previously owned 1999 Disco 2 TD5
Post #619711 Fri Dec 03 2021 2:22pm
MartinsTDV8
So a new one is on its way from AUTODOC at £545 delivered Big Cry Big Cry Previously owned 1999 Disco 2 TD5
Post #619731 Sat Dec 04 2021 12:54pm
