Home > General > 2013 L320 tailgate Strut
neill3997
My passenger side tailgate strut keeps coming off the ball joint. I have bought new strut.
Just wondering how easy it is too fit this and how to get into the electric clip to replace.
Post #616577 Sat Aug 14 2021 8:30am
You need to remove tailgate interior trim panel to get access to the electrical connector.
https://drive.google.com/file/d/1-jkycFwZn...sp=sharing
Post #616592 Sat Aug 14 2021 10:36pm
Duc750
I'd replace the ball joint too if you can - having just had struts replaced on ours and getting similar symptoms almost straight away new balls sorted it 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #616638 Mon Aug 16 2021 8:12pm
Stavroskon
Greece 2013 Range Rover Sport SDV6 HSE Santorini Black
Hello!! Yesterday I replaced two electrics struts !!!! You must remove the handle cover with flat knife , you must remove the 2 screws under this cover … then just unclip the plastic trim … you find the connectors inside lower panel ! The problem is that after this job my tailgate opens and close continuously.. press to open tailgate opens then close !!! My tail gate doesn’t stay open !!!! Any suggestions???
Post #619702 Fri Dec 03 2021 7:46am
