Home > General > Window switch - problem |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
The electrics will be OK - it will be the lever itself - where it pivotts it breaks hence why it works sometimes - if the lever is in the right position it works, if it is not the switch will not work - it is the mechanics of the switch.
Thu Dec 02 2021 12:51pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
I think its more a case of having to remove the trim panel first, to disconnect switches.
Thu Dec 02 2021 1:11pm |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 310 |
Thanks for the advice. Might try to take the switch out perhaps order a replacement first? Andrew Kennedy |
Thu Dec 02 2021 2:50pm |
A question re my need for a replacement of the bank of 4 window switches. ITS AN EXPENSIVE ITEM and from what you tell me probable not worth buying second hand. When I take the car in for a service next time (very good local guy) would you consider the switch mechanise reparable???! Andrew Kennedy |
Fri Dec 03 2021 6:01pm |
I'm being quoted £99.01 for a new replacement to the window switches on the driver door!!!! I understand from your remarks that the switch mechanism is quite delicate. If I go for a used second hand one, just looking at it, would it be obvious its going to be in good order? I would imagine its a sealed unit?!? Andrew Kennedy |
Sat Dec 04 2021 9:44am |
I have not bought new replacements - always second hand - just make sure the plastic hinges are not broken.
Sat Dec 04 2021 11:45am |
If you buy online, from eBay. You should get a refund if it doesn’t work |
Sat Dec 04 2021 8:07pm |
