Home > General > Radiator Viscous Fan
Whoosh
Morning Folks
I have a 2.7 tdv6 2008 84000 miles
I think my cooling fan is faulty as when the engine is cold the fan is fully engaged on start up and continues to be fully engaged .
I’ve turned the blades by hand and they are stiff and not free at all .
There is also a loud roar .
Does this sound as if the fan is gubbed
Can I also ask what is the electrical connection to the fan
Post #619658 Thu Dec 02 2021 10:06am
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Silly question, but are you sure its not the coolant heater? Mines been doing it since the cold weater.
Post #619659 Thu Dec 02 2021 10:23am
Whoosh
No it’s definitely the fan it would appear not to be free even when cold πŸ‘
Post #619660 Thu Dec 02 2021 10:28am
Bertbuckie
Afraid I am of no help then sorry. Good luck Smile
Post #619661 Thu Dec 02 2021 10:33am
Whoosh
πŸ˜‚πŸ˜‚ not at alll πŸ‘
Post #619662 Thu Dec 02 2021 10:42am
I think it does a self test after startup, but if it carries on for longer than 1 minutes, you have a problem
The electrical connector tells the fan to run harder (engine ecu controlled), for example when the A/C is on or when coolant hot.
Also has a speed sensor
Pressing the ECO button on the climate panel, should change the note/speed of the fan and this is a good test
Post #619667 Thu Dec 02 2021 1:06pm
Whoosh
Thanks for the help think my fan is pumped it’s doesn’t stop after start up it keeps running and there is no difference when the eco button is activated/de activated.
So I think I need to invest in a fan πŸ‘
Post #619676 Thu Dec 02 2021 4:28pm
Stevepd
Mine does it upon first start for approx 40 meters. Then I reach a T junction and I notice the noise has gone. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #619682 Thu Dec 02 2021 7:05pm
did u have the car in the summer? and know the A/C works ?
Viscous Fan always run a bit
Read the engine fault codes and see if any fan problems reported.
Post #619684 Thu Dec 02 2021 7:40pm
Whoosh
I never had the car in the summer although I was told the system had been serviced /re gassed .
I know the fan will run all the time but mine in at full speed from the second you start the car until you stop it it never changes .
πŸ‘
Post #619686 Thu Dec 02 2021 8:15pm
Whoosh
The car is going into local Indy garage for a intermittent suspension fault and a general health check so will get them to check .
Thanks for your help πŸ‘
Post #619687 Thu Dec 02 2021 8:17pm
