![]() | Home > General > Headlights not very good |
| nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113
I had the hid bulbs on my 2008 RRS and they were honestly the best I have seen until my D5.
| Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1058
?? Not sure whether you're saying dipped is bad or mains are bad. Dipped are HIDs and mains are "normal" bulbs.
Ah... I had dual xenon HIDs. |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
They were all dual xenon.
| peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 49
Xenon in the high\low section and halogen in the high 'spotlight' section.
Yes - badly worded on my party, sorry - the 2 outer lights are HIDs and the two inner main beam only/spot ones are halogen. But definitely worthwhile replacing the halogen ones with LEDs |
They fitted halogens for a reason I think. That halogens are good for long range. The inner reflectors are also setup for long range. But if it works for you....
| lkdgndg1 Member Since: 15 Jan 2021 Posts: 32 |
It’s my dip beams that are not so good , the mains are ok and just halogens but the dip beams are HIDS and on a dark road very poor , I’ve replaced them twice with sets from Amazon but didn’t pay much for them say £20 per pair but the originals were Phillips and still poor , could the light assembly get weaker inside due to age (2009) and need a clean and polish , the lens are clear , I don’t fancy a new pair as nearly 1k per side , next step apart from taking the lights apart is a set of Osram night breakers . |
well maybe its something to do with the AFS system
| RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280
I recently replaced my 2008 original HID lamps with Osram Night Breakers @ £80 for the pair as felt the dipped beam had lost its efficiency in my 10 years of ownership
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
What do mean when you say they are very poor? Is it the amount of light being produced or where the light is? They might just need adjusting which you can do using the two screws on each light unit. The lights on my 2008 TDV8 with AFS were the best lights I've had on a car - once I'd adjusted them and put in decent bulbs. Osram Nightbreakers in both the HID and the H7 fittings. They were better than the lights on my current 2012 which has a strange beam pattern although they chuck enough light down the road so they're still pretty good. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
I'd add my support for the standard lights on the RRS. Mine are excellent and the best on any car I've owned. After a summer of light evenings where you don't use them so much, to now where it's getting dark at 4pm I really notice how good they are.
It’s the dip beam light brightness I’ve adjusted them up but the amount of light seems very poor , I’ve bought some nightbreakers to see if that improves things but the standard lamps should be better than this , that why I was wondering if I need to take the lamps apart and clean them , the plugs on the back are all clean with nice bright contacts |
Anyway thanks for all the replies, I was just wondering if Range Rover sport lamps were good or bad , but seems they should be good , mine are probably needing adjustment as the AFS system was inop and now I’ve sorted that and found the settings all over the place but never very bright so will fit these Osram night breakers and then if still dull take the lights apart for a clean and polish |
| All times are GMT |
