![]() | Home > Faults & Fixes > 2009 Range Rover Sport TDV8 Many Warning Lights & Messag |
| cliffman007 Member Since: 05 May 2017 Location: Truro Posts: 9
Further to my post I have just been out for a quick test and all five lights and messages came on within a few miles! Same message about the ACC Sensor Blocked could this cause all these lights and messages to come on at the same time? |
Are any of the tail lights blown? A failed rear brake lamp can throw up a dash full of warnings 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
You would need to tell us what yellow warning you have and what the DTCs are. 2019 5.0 SC SVA (Current)
Update: -
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
A loose ABS sensor would cause all of those lights because they all relate to dynamic control systems that use the ABS sensors in some way. Hopefully if they have fixed the sensor then the rest should go away too. 2012 SDV6 - it's missing a couple of cylinders
| PaulWhite Member Since: 22 Oct 2014 Location: Weymouth Posts: 10
I have the same or at least similar problem but the car won't even limp, masses of lights come on and it just slows down completely.. The engine keeps running but absolutely no power. Switch off, and wait a few seconds. Switch on and all is well.
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
My thoughts won't fix all your problems I'm afraid but low power could be a leak in the intercooler pipes. An easy thing to check for at no cost. I'm afraid it sounds more serious than that but easy to check and fix if necessary. Robin
Thanks for the suggestion. If you mean the two 2.5" pipes that go from above the radiator to the engine, they were replaced a short while back. I have had that fault before because the pipes deteriorate quickly. However when that happens I only ever got an engine error and not a complete christmas tree. I am going to the workshop this morning and will of course ask them to check the pipes again.
An added note. The workshop have found that the fuel filter was almost blocked. Evidently it had never been replaced on my 09 RR. Seems to run very nicely now but only time will tell if this was causing all the warning likes to come on.
| All times are GMT |
