![]() | Home > In Car Electronics > Not reading Sim card |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1902 ![]() ![]() |
If you are sure you are putting it in the correct way then a Card Reader problem.
Mgs1000 Member Since: 21 Nov 2021 Location: Oxford Posts: 34 ![]() ![]() |
I’m sure I’m putting it in correctly, it’s a fiddle but it does click into place.
It does click into place, not sure about cost of replacement as the older posts are regarding cars that were still in warranty. 2023 P440e SE Dynamic on order -cancelled
AlM Member Since: 08 Feb 2021 Location: Melbourne Posts: 52 ![]() ![]() |
I had a similar problem with a MY21.5 RRS. The dealer replaced the SIM card reader. Evidently a not unknown problem- they had plenty of spares! All good now. MY21.5 HSE 221KW D16
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 143 ![]() ![]() |
I'm on my third card reader so far and expect another at some point. All covered on warranty. |
Wilco Member Since: 20 Mar 2021 Location: Somewhere in Time Posts: 31 ![]() ![]() |
Had a similar problem, dealer found slot was full of fluff/dust, so card was not engaging fully in slot.
Discovered a new quirk… Apple CarPlay and the SIM don’t play nice together. If I plug up the iPhone before the SIM has been read by the Infotainment system, then the SIM will not be recognised, and vice versa.
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 352 ![]() ![]() |
Do you use any data sim ? RRS HSE DYNAMIC 2015 ODESSEY RED |
I have always used the Three SIM. 2023 P440e SE Dynamic on order -cancelled
On average how much data per month ? RRS HSE DYNAMIC 2015 ODESSEY RED |
I use EE, but I reckon the maximum it uses is 100mb unless it needs an update. |
Thank you will look for a deal on 2gb to be on safe side RRS HSE DYNAMIC 2015 ODESSEY RED |
