Home > Maintenance & Modifications > Maintenance Catchup Advice - Sketchy history
rich_959
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Stornoway Grey
Afternoon all,
A few months back I bought a 2009 (2010 MY) RRS, 3.0 from a friend-of-a-friend in the trade who took it in as a part exchange. It didn't cost a lot, and I'll be using it as a bit of a workhorse (a bit of car trailer towing, plus family duties). It's in fairly good order and drives remarkably well for 135k miles on the clock. However, history is sketchy with the last stamp in the book being 2018 at 80k miles (full LR history up to that point - just A's and B's). The story is that the last owner had a friend do maintenance for cash in hand and never had any receipts. That old chestnut.
It's had new lower arms and tank cradle recently (I can see they're still shiny) and I put it into my local small garage for an initial check over. They did rear discs and pads and a pair of front bearing assemblies (as I noticed one was whining). I put a new set of wheels and michelins on it, as a set came up at the right price nearby on fleabay.
I think it's safe to assume that it needs the cambelt(s) and a decent service, but I wanted to see what else you guys thought made sense to do at the time. The car only stands me £6k, and I don't want to go nuts on it, but I also would like to get a few years motoring out of it, and show it a bit of care. Would you suggest doing diff oils etc, and main transmission oil? Anything else? I realise it's a bit of a subjective question but any general advice is appreciated.
All the best,
Rich.
Post #619209 Tue Nov 16 2021 5:09pm
Belts should be done yesterday, if not sooner, obviously. Otherwise, I'd do a gearbox flush, and change the diffs and transfer box fluids too. Otherwise a full service at a decent LR indie specialist would do the job and ensure decent filters etc. are fitted. 2012 SDV6 - it's missing a couple of cylinders
Post #619214 Tue Nov 16 2021 5:40pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
+1 and it puts your mind to rest for a few thousand miles.
Post #619216 Tue Nov 16 2021 5:56pm
andywatson
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
Just had full service on my recent acquisition no history with purchase, well there is but not for this car, another story!
Also gearbox flush
 2008 RRS 3.6 HST - Stornaway / Black - Current
2010 RRS 3.0 HSE - Nara Bronze / Almond - Gone
2009 RRS 3.0 SE - Sliver / Teal
Post #619218 Tue Nov 16 2021 7:56pm
rich_959
Thanks for the replies guys. Booked in for cambelts, service and diffs/transfer oils.
Post #619677 Thu Dec 02 2021 5:13pm
DrRob
Megaflush the main gearbox. Bodsy is your man. Comes to you. Does transfer and diff oils too.
Change the PAS fluid and coolant and brake fluid.
Basically do all oils and filters * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #619683 Thu Dec 02 2021 7:40pm
rich_959
Thanks! Do you have contact details for Bodsy, and do you know if he covers East Yorkshire?
Post #620070 Fri Dec 17 2021 1:56pm
Stevepd
Here you go
Drop him a What's App on 07770638023 2006 2.7 TDV6 HSE in Cairns Blue.
Post #620084 Sat Dec 18 2021 9:56am
rich_959
Just some feedback on this, following the major service, plus cambelt and and all fluids (including gearbox, transfer box and both diffs). I'm amazed at how much of a difference it has made. Seems to be rolling much better and getting average of 32mpg where it used to get around 28.
Plan to put a pair of struts on the front and a new compressor, then see how it goes. Is it only a landrover specialist that will be able to do suspension calibration? It sits a little low at the front, and I don't know if that's just down to the knackered shocks, or if it will all need calibrating.
Post #623079 Thu Mar 24 2022 2:35pm
