| RRSPORT.CO.UK | ||
|  | Home > Technical > Track rod end - ball joint splitter/separator |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | What we quite often did on heavy trucks was lever down with a bar between the end of the track rod and axle and give the the bit the track rod taper fits into on the stub axle a good wack with a lump hammer more often than not worked, leave the nut on a few threads though if it does move suddenly you might headbutt the car if applying a lot of weight to the bar. Only a suggestion but might work.
|  Tue Nov 09 2021 8:31pm |
| Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321      | The clout with a 4lb lump hammer worked for me, one track rod end was stubborn so I used my old fork type splitter on that. The problem is the threaded studs are so long most splitters won’t fit. Steve
|  Tue Nov 09 2021 9:11pm |
| blueraccoon Member Since: 03 Oct 2021 Location: Essex Posts: 9      | Now resolved with a hefty further clout of the hammer and it popped out. Cheers all | ||
|  Wed Nov 10 2021 11:16am |
| Posting Rules
