Home > Maintenance & Modifications > Oil suction device recommendation
Stevepd
Hi folks what oil suction device are you using please, or steerer clear. Must include tubes for a 2.7 engine, whatever diameter it may be for the dip stick. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #618882 Mon Nov 08 2021 1:28pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi I purchased this one for my RRS 2013 https://www.ebay.co.uk/itm/254930697017?ha...SwU21fN7~B
I used it it worked great with my RRS I have the suction tube as I don’t have a dipstick unfortunately!!!!.
I decided after I had got the oil out to remove sump plug just to check and I had nothing bar a dribble of oil .
I fitted new oil filter and fastened it all back up, you do need to remove oil filter prior to removing oil.
I can say it worked we’ll i filled it back up with Millers 05w/30 C1 and did the various checks across an hour checking the new oil level. Thumbs Up
Post #618894 Mon Nov 08 2021 3:17pm
