![]() | Home > General > Number plates |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 208 ![]() ![]() ![]() |
I use double sided 3M tape on all my plates. 2018 Telsa MS
houghta Member Since: 22 Oct 2021 Location: Cramlington Posts: 68 ![]() ![]() |
With the front I heat the plate as I fit it so it bends to the shape of the bumper. Andy.
Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 80 ![]() ![]() ![]() |
My front is screwed on, but I used pads (lots and lots) on the ack, mainly because the existing hole would have meant that the screw was through the Union Flag. 2010 HSE TdV8 in Stornoway Grey.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Have used double sided foam tape/number plate tape for many years and it's more of a concern on whether the plate will come off without breaking rather than falling off. Sensible bends isn't a concern either.
Martyn Member Since: 28 Jun 2019 Location: Suffolk Posts: 64 ![]() ![]() ![]() |
I always use the double sided tape that's used to stick sealed unit windows in I've never had any plates fall off using this |
evolution380 Member Since: 09 Dec 2020 Location: Derbyshire Dales Posts: 16 ![]() ![]() ![]() |
On My L494 i used pads with no issues front and back, did use a stubbier 5 digit plate though which may have helped reduce any bend. |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
The cheap stuff falls off as soon as you look at it (Halfords, I'm looking at you .. but maybe mine had just been sat in a drawer too long) - the stuff I've had come with plates has always worked fine, though. On your second point - imagine my disappointment when I took the plate off the back of my BMW to find that: a) The previous owner/dealer had used a screwdriver to pry the plate off, leaving lots of lovely gouges in the plastic bumper (which the new plate only covers if you put it not quite in the right place, grr) b) There were also screw holes ![]() ![]() |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
This topic reminds me of when I was 17 and with no real world clue!, I had fitted a private plate to my audi a3 with some available mastick that was kicking about at work and when I sold the car and went to pull off the plate the paint came with it!
