Home > General (L494) > Remote heating
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Remote heating
Hi my car has remote heating that you turn on via the Land Rover app. Only problem is if I don’t use the car for more 4 days it goes into sleep mode and I can’t use it which is ridiculous really. Any idea how you can extend this time period? Attached is a pic of what the app says.
Post #618534 Sat Oct 30 2021 11:29am
jimbg
Check the options, there is a facility somewhere to wake it up.
Do not have access at the moment to check exactly. Thumbs Up 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #618535 Sat Oct 30 2021 12:11pm
Johnrrs
Yes I have seen the wake up feature on the app but you can only set a day when you want the car to wake up so you can use the remote heating. Ok if you know which day you will use the car. I have a van I use as my Dailey driver so sometimes won’t use the Range Rover for 2 or 3 weeks. If I could wake the car up on the day I was going to use it would be good but you can’t wake it up on the same day for some reason, it only gives you the next day onwards as an option. On my last RRS I had a separate fob for the remote heating and was fantastic. Could use it anytime you wanted and never ever failed to work unlike the app operated version where sometimes you press start on the remote heating app then it waits a few minutes until it connects to the car and then sometimes never connects and says there is an error but you don’t realize until you get in the car and it’s cold. Give me the separate fob to work this any day…..
Post #618539 Sat Oct 30 2021 5:39pm
jimbg
Do you actually have the FBH on your car?
Then maybe you can get a remote fob set up?
bits are listed here https://www.rrsport.co.uk/forum/topic55467.html 2026 P460e Autobiography on order
2006 HSE
Post #618540 Sat Oct 30 2021 5:47pm
Johnrrs
Yes it has the FBH fitted to the car from new. I assume that if I bought the remote by itself it would not work as I assume it would need the receiver unit to work it. When I bought the car 4 years ago I questioned where the remote heating fob was as I knew I had the remote heating fitted. They assured me they don’t come with the newer shape RRS and it’s all done via an app on your phone which it does.
Post #618542 Sat Oct 30 2021 6:23pm
teldec
what year, mine is a 2015 and has a separate remote for the fbh
Post #618632 Mon Nov 01 2021 11:50pm
Johnrrs
Mine is a 2015 reg but 2016 MY. I don’t have the separate fob, I use the Land Rover app on the remote climate bit. Can you use yours on the app too?
Post #618653 Tue Nov 02 2021 10:37pm
teldec
yes i have the incontrol app etc as well
Post #618655 Tue Nov 02 2021 11:09pm
Johnrrs
Mmmm that’s interesting, did it come with the car when you purchased it?
Post #618658 Wed Nov 03 2021 12:16am
teldec
That i could not tell you as i purchased it used but like yours is a 2015 but 2016 build spec, mine is a sdv8 so i think the fbh is standard on those
Post #618661 Wed Nov 03 2021 8:27am
Johnrrs
Mines the SDV6 so maybe that’s the difference then as I think the FBH is standard on the SDV8.
Post #618705 Wed Nov 03 2021 9:31pm
Johnrrs
Just looked at my topix spec sheet. It states fuel burning heater and park heating with remote control as separate items. That to me says I should have a separate remote for the park heating. I’ll call the dealers over the next few days and see if they can shed any light on it.
Post #618708 Wed Nov 03 2021 10:02pm
TheGoodWillOut
looks like you're running the old app, is it the same if you install the new app ?
Post #618725 Thu Nov 04 2021 2:52pm
Johnrrs
Just tried the new app and it’s exactly the same only there is no option for the wake up timer. It says car must be manually started to resume remote features. Photo of it is attached
Post #618747 Thu Nov 04 2021 10:20pm
Johnrrs
So I thought I’d use the wake up timer on the remote heating tonight and wake the car up tomorrow as I knew I was going to use it then got this on the app. Surely the 4 day thing on the sleep mode of the car can be altered?
Post #618786 Sat Nov 06 2021 12:07am
