![]() | Home > General > Chassis question |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
They are harmonic mass dampers. They are used to tune the chassis' response to vibrations etc. They basically make the car a nicer place to inhabit. 2012 SDV6 - it's missing a couple of cylinders
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
They are Harmonic Damper weights supposed to help stop resonating noise/vibrations. They did move enough at one point on my car to knock on the bumper under sharp braking and made it sound like a knocking suspension, just wrapped a bit of foam rubber to them and cured that. There are a couple of similar lumps of metal bolted on to the chassis underneath the front door post area although the are fixed, assume they are for a similar purpose, same as the small metal blocks blocks bolted to the front calipers on the TDV8 Brembos.
| lkdgndg1 Member Since: 15 Jan 2021 Posts: 32 |
Lovely thanks for the info I was wondering what they were there for now I know thanks. |
| All times are GMT |
