Home > General > Anyone Fitted A Ctek Comfort Indicator Panel?
Lindab
I have the comfort connector hidden in the bumper valance. Just pull out, connect & when finished it sits inside the valance. You would never know it was there & no opening/closing the bonnet Thumbs Up
 Range Rover Sport: Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S
Post #617530 Tue Sep 21 2021 3:23pm
knwatkins
Or there's always the option of mounting the charger within the car itself...
https://www.rrsport.co.uk/forum/topic55319.html Kev
Post #617541 Tue Sep 21 2021 7:32pm
Pufftmw
Andy K wrote:
I prefer putting it in the boot. Depends where you park really
This site also sells a towbar plug (if you park in a garage and have a 7 pin white tow socket)
I have one of them Thumbs Up Fortunately I live nowhere near oiks, so get away with it.
Post #617544 Tue Sep 21 2021 7:57pm
Pufftmw
Col wrote:
Could try one of the bm2 type battery monitors and use the app on your phone to check charge state, they are quite accurate.
Cheers Col Thumbs Up
Going to go with one of them - £19 on Amazon with a free app. Not sure if its BM2 but should be enough for me to monitor it Smile
Post #617546 Tue Sep 21 2021 7:59pm
Pufftmw
Now - anyone use a solar panel to keep the battery topped up?
Post #617547 Tue Sep 21 2021 8:00pm
Autobiography1969
Solar Panel..
If you have tinted glass its wont work well enough.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #617548 Tue Sep 21 2021 8:08pm
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
has anyone mounted a solar panel on the roof?
a flexible stick down type one?
Just to keep the battery topped up 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #617582 Wed Sep 22 2021 2:26pm
Scrumpy
I use one on the inside front windscreen that plugs into the OBD port and seems to work well enough if I'm going to leave the car for a week unused.
Just need to make sure I park facing the sun!! 2016 RRS SVR Estoril Blue
Post #617584 Wed Sep 22 2021 3:23pm
Pufftmw
Autobiography1969 wrote:
Solar Panel..
Well, I was thinking of putting it in the front windscreen as where I park, the car is facing south
Post #617611 Wed Sep 22 2021 8:38pm
Ken 153
United Kingdom 2010 Range Rover Sport Supercharged HSE Galway Green
Update to this thread;
I've been in discussion with NOCO about the battery Booster X45
to ask if it can be used as a trickle charger as they do a Fag Lighter extension lead - but it won't work with that model as its purely a starter booster, but they said that the cable could be used in the aux output in the boot to charge/top up the battery.
I already have a CTEK trickle charger so following the advice given from NOCO I have now just ordered on of these
to see if it will work... I see this as an easier option to use so I don't/won't have to open the bonnet to charge "Greta" up, plus I will be able to close the boot and set the alarm on her....
Post #618259 Thu Oct 21 2021 1:29pm
Lindab
The boot output is not powered when the car is locked.
I ended up connecting up another socket connected to the battery so I have the facility to use either the boot or front depending what direction the car is parked Range Rover Sport: Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S
Post #618262 Thu Oct 21 2021 2:19pm
Pufftmw
Lindab - you need to read THIS if you want a permanent live in the rear 12v socket
Post #618273 Thu Oct 21 2021 9:18pm
Ken 153
Post #618278 Thu Oct 21 2021 11:13pm
Autobiography1969
Can anyone tell me and others that might want to know
what gauge wire and what size spade connectors are required to do this safely?
And would it be any safer with a fuse between the spades? ===========================================
Post #618279 Thu Oct 21 2021 11:31pm
Lindab
I did not want to be changing the existing wiring to the original socket & have never used it anyway. That is why I added a new socket with inline fuse. When not in use it has a cover that shields it. Only a couple of pounds from Ebay Range Rover Sport: Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S
Post #618285 Fri Oct 22 2021 8:04am
