Home > Technical > Rear view cam. No steering direction lines |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
Seen a similar post on this before,,, I maybe wrong but not sure if it depends on the type of reverse camera you have,,,, surround type or rear only,,,, surround type has the reverse lines. 2010 RRS, TDV8
Mon Oct 11 2021 7:27pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Not sure about the RRS2 but on the facelift RRS1 you can turn various graphics on or off via the screen menu by touching the screen while reverse gear is engaged, as mentioned sure you only have "bendy" yellow lines with surround cameras but as said that is the RRS1.
Mon Oct 11 2021 8:50pm |
RRS Dave Member Since: 11 Oct 2021 Location: Suffolk Posts: 24 |
Thanks for your help guys |
Tue Oct 12 2021 7:50am |
