Home > Maintenance & Modifications > L494 - Rear Bumper upgrade - Sensor Connector & Exhaust
911-RRS
Hi everyone.
Sorry if this has been covered before.
I have just purchased a 2019 Facelift Used complete rear Bumper in order to upgrade my 2014 RRS 5.0 S/C.
The New upgrade bumper has 'Side Sensors' ( 6 in total) & my existing bumper only has 4 sensors.
The question is will the new bumper wiring connector still plug in and work correctly or do I have to swap looms over and use the outer sensors as 'Dummys'?
I haven't started to strip the old bumper yet but a heads up to the work involved would be appreciated prior to starting.
Also does anyone know how much I will have to cut & reduce the existing exhaust tail pipes by so they pipe 'Fit inside' the Static Bumper exhaust tips? As I have the 5.0 Petrol the Exhaust is 80mm in Diameter & 'Straight'.
James
Post #618030 Mon Oct 11 2021 12:58pm
Red Arrow
Just stick two dummy sensors in the side ones Thumbs Up
Post #618032 Mon Oct 11 2021 4:31pm
911-RRS
Thank you 'Red arrow'
Yes I can swap the Looms over and have two dummy sensors - but I don't really want the hassle
Do you know the connector is definitely not the same ? If so it could be just a 'plug and play'
Post #618033 Mon Oct 11 2021 4:39pm
