![]() | Home > Technical > V8 tdi Engine sys fault |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216
Been doing a bit of research on the code I have P000E-00. Vehicle runs out of power but will restart, eg. ign/on/off.
deleted |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784
I have no idea what your fault is, however it clearly is a fault and you should be aware of your legal rights, as I've no doubt the garage does!
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
Agreed. Take it back and tell them to sort it out to your satisfaction. 2012 SDV6 - it's missing a couple of cylinders
| Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 80
My TdV8 had a split Intercooler hose, symptoms were black smoke and jumping into Restricted Performance, switching off and on cleared it.
I dont think any of the hoses at fault .
Can I ask what would be average fuel consumption for most v8's out there I'm just wandering if mine is too high as I would guess on local 12/24 mile runs should be more than 20 mpg.
Can I ask what would be average fuel consumption for most, I'm just wandering if mine is too high as I would guess on local 12/24 mile runs should be more than 20.5 mpg.
| Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84
Around town, I can get up to almost 22mpg if I drive like Miss Daisy. |
| Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225
Worst is 19mpg best is 30mpg. |
Oh well , just trying to work out if this fuel volume sensor might help me solve this issue. |
OK , looking for a good guide to replace the drivers side intake manifold , its cracked, This will no doubt be the trouble behind the fault , at last. The seller has agreed to give me a replacement but not the fitting.
The first fault showing the engine faults would I think relate and cause the other faults. Any help appreciated!
Sorry the last picture would be the fault to go on. So looking for help.
