Home > General > Steering columb adjustment
lkdgndg1
Hi my 2009 sport HSE the steering columb adjustment does not work at all , I’ve tried looking for help with this and all that comes up is with the l322 which is different , I’ve tried all the fuses and plugs I
On the unit but it doesn’t work in man or auto not even a click from the unit , does anyone have a fix or an idea what to do as I’d like to repair it myself rather than use a dealer or independent, I have no fault codes on my ICarsoft reader.
Any help would be great thanks .
Post #617696 Sat Sep 25 2021 9:54pm
someone having the same issue here, but no solution yet
https://www.disco3.co.uk/forum/id-tool-hel...97165.html
Post #617702 Sun Sep 26 2021 10:11am
lkdgndg1
Hi and thanks for the link , yes I’ve the exact same problem and will try to sort it out thanks though
Post #617706 Sun Sep 26 2021 12:34pm
lkdgndg1
Hi they mention an ID tool ,what is that and where can I get one from
Post #617713 Sun Sep 26 2021 2:02pm
RugHead
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
https://bellautoservices.co.uk/store/iid-bt-tool-gap-diagnostics/
There are also a few other places in the UK that sell them too.
Post #617715 Sun Sep 26 2021 2:42pm
They are £500
Post #617717 Sun Sep 26 2021 3:14pm
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Re: Steering columb adjustment
[quote="ssc100"]Hi my 2009 sport HSE the steering columb adjustment does not work at all , I’ve tried looking for help with this and all that comes up is with the l322 which is different , I’ve tried all the fuses and plugs I
Any help would be great thanks .[/quote
The sport I have just bought says it an HSE , is a manual adjustment .
Post #617720 Sun Sep 26 2021 6:21pm
lkdgndg1
Hi alfapat my HSE doesn’t have any manual adjustments and is only fully electrical , just the auto/man switch and no manual unlocking lever underneath the column.
Post #617723 Sun Sep 26 2021 7:13pm
lkdgndg1
Andy K wrote:
They are £500
im thinking it may be cheaper to get a specialist to check it for me as those tools are quite expensive .
Post #617724 Sun Sep 26 2021 7:15pm
alfapat
Strange that? Maybe depends on age . Mine is a 57 plate , maybe yours is newer.
Post #617726 Sun Sep 26 2021 7:44pm
lkdgndg1
Hi yes mines an 09 .
Post #617729 Sun Sep 26 2021 8:49pm
ssc100 wrote:
Andy K wrote:
They are £500
I though that might slow you down Rolling with laughter
The autel AP200 WHITE is worth considering for other things. (from £44)
Electric column came in around 2007 I think
Post #617743 Mon Sep 27 2021 7:36pm
lkdgndg1
Hi Andy and thanks for that , I have an ICarsoft for the Range Rover but can’t justify 500 for the IID tool, well not unless I’m going to use it a lot , I’ll check out the AP200 though thanks .
Post #617843 Sun Oct 03 2021 9:54pm
