![]() | Home > Maintenance & Modifications > Intake Manifold Split - Leaking Rear ARC bar |
Might be worth a second opinion and quote.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9066 ![]() ![]() ![]() |
Split inlet manifolds are a known issue. If you're going to do one, get the other done at the same time - the cost is in the labour of stripping the gubbins off the top of the engine. Doing both at the same time doesn't add much labour time. The manifolds are less than a couple of hundred quid each (https://www.advancedfactors.co.uk/inlet-manifolds--engine-cover-11658-c.asp).
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 ![]() ![]() ![]() |
Mine went not long ago, local garage did it for 1150 including timing belt. Only did one side as the other had been done |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 71 ![]() ![]() ![]() |
My inlet manifold split - not much fun
My indie told me that they generally found that once an inlet manifold has been replaced it's generally ok for good. I wonder if there was a design change after the first few years of the 3.0 V6 diesel and the replacement parts are of the later design. 2012 SDV6 - it's missing a couple of cylinders
I hope they are correct - would be nice to not have to do that again! Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
There was a design change, there is a service bulletin about it, the original plastic in the side radius was too thin.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4472 ![]() ![]() ![]() |
Manifolds have been revised 7 (!) times, with the most recent version released in 2018
