![]() | Home > General > Manual Park Brake Release Not Working! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5123 ![]() ![]() ![]() |
Assuming you have a 2013 RRS2 and not the RRS1 based on your description of the h/b release lever, you could try this from under the car.
sb1972 Member Since: 10 Sep 2021 Location: Durham Posts: 8 ![]() ![]() ![]() |
Hi Colin, sorry - my car is a RRS1 - very last of the original shape sir. |
My mistake I thought the emergency release cable for the park brake on the RRS1 just had a ring on the end of it, and you used the hook part of the jack handle to give it a good pull. Are you sure you are not pulling on the emergency park lock release cable lever for the auto transmission? that could explain the gear shifter light/park issue.
Col - I’m ashamed to say you could be correct - I’ve been yanking the hell out of that thing in your picture! Where on earth do I find the loop sir? |
I found some information you had previously posted on this matter Col. I have located the steel wire loop beneath the parking brake switch. I’ve had the Jack handle hook through the loop with a screwdriver at the other end. Despite my efforts it still won’t budge - mostly because whenever I pull hard the Jack handle strikes the metal frame inside the console. How far should this metal cable come out? At present it moves an inch and a half which leaves most of the Jack handle deep inside the centre console - making it virtually impossible to give it a decent ‘yank’ |
