![]() | Home > General (L494) > Cannot get tinted rear windows clean!? |
JETPAK Member Since: 28 May 2021 Location: Bellingham, WA Posts: 10 ![]() ![]() ![]() |
My rear passenger windows have what looks like small water spots all over them. I've tried, in this order, on both inside and out: Windex, SprayWay, denatured alcohol, ammonia, vinegar. Nothing makes any change. The spots aren't on the front side windows which are less tinted, so I wonder if it's something related to the tinting. The RR is fairly new to me so I don't know what might have started the situation.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5081 ![]() ![]() ![]() |
Are they factory Privacy Glass or a Aftermarket Film and the marks are under the film?
I'm not sure and not sure how to tell. I have zero history on the car as it was in Canada and they don't give out any history info. The rears are definitely darker than the front passenger windows. 2014 Range Rover HSE Supercharged
Appears they are original glass but don't know if any aftermarket work was done. 2014 Range Rover HSE Supercharged
Thanks. Makes sense now. Was driving me crazy. 2014 Range Rover HSE Supercharged
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Open the window slightly. Look closely at the top of the glass. If it was like mine and a the tint was an AM film there will be a very small gap between the top of the window and the tinted film paper starting, about .5mm.
Thanks! Will check it out. Hopefully it's that easy! 2014 Range Rover HSE Supercharged
I think it depends on how professionally it was applied. I always thought my windows were tinted until the vehicle inspection here - which was done more thoroughly than anything I've ever seen on CSI! I literally pulled each one off sheet by sheet. Dishwasher soap and hot water got rid of the sticky residue left on the window. Barrie.
