| RRSPORT.CO.UK | ||
|  | Home > General > Tdv8 3.6 sump |
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1924    | Use a vacuum pump to suck the oil out? 2026 P460e Autobiography on order
|  Thu Aug 26 2021 7:56pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | There are two drain plugs on the TDV8. Both should be used. If the lower one is stuffed, how about draining the other one and then using a suction pipe down the dipstick to get out the remainder? 2012 SDV6 - it's missing a couple of cylinders
|  Thu Aug 26 2021 8:12pm |
| Jefus957 Member Since: 26 Aug 2021 Location: Stoke on trent Posts: 5      |
 Thanks for reply Iv'e already tried sucking oil out via dip stick but its only removed a couple of pints have thought of removing oil temp sensor to drain it that way | ||
|  Fri Aug 27 2021 8:14am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | As said, there are two drain plugs so it might be worth using the other one and seeing how much you get out.
|  Fri Aug 27 2021 8:50am |
| Jefus957 Member Since: 26 Aug 2021 Location: Stoke on trent Posts: 5      | Perceived with the suction pump and after what seemed like forever finally got the oil out poured some fresh oil in and sucked that out aswell so now its replace turbo drain plug the filter and top up with oil thanks for comments 👍 | ||
|  Fri Aug 27 2021 7:38pm |
| Posting Rules
