![]() | Home > General > Beeping Outside Once Turned Off |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 147 ![]() ![]() |
Mine does it too but I’ve no idea what it is. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Are you sure it it from the rear and not the engine bay - when you shut down the EGRs go through their cleaning shutdown process that lasts about 20 secs and can sound like beeping sometimes. 07MY RRS TDV6
Takemetothepub Member Since: 05 Jul 2021 Location: Essex Posts: 3 ![]() ![]() |
I'll pop the bonnet and find out but 90% sure it's from the rear underside. |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1203 ![]() ![]() ![]() |
on the Puma, this is the turbo that is kept spinning to cool down.
It sounds like a digital man mad beep, though. Like it's supposed to be doing it. I'll try and get a video and post it. |
Sounds different to that. This is like an electronic beeping sound. I’m not worried about it, mines mine doing it since the day I got it amongst the many other little sounds it makes when it’s off. With regard to the turbo. Is the turbo kept running or is there an electric aux oil pump to cool it down - to me it sounds like the latter as I can clearly hear this in the engine bay. |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 184 ![]() ![]() ![]() |
Anyone get to the bottom of this? My MY20 does the same thing L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
