![]() | Home > Maintenance & Modifications > help and advice needed |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
1 transmission breather silver pipes
Ianm2911 Member Since: 09 Aug 2021 Location: Evesham worcs Posts: 14 ![]() ![]() ![]() |
thank you andy so the breather pipes don't connect to anything and everything else seems to check out so will try easy start tomorrow and see how it goes |
Spray a bit in before the Y intake |
Ok starts up on easy start but cuts out as soon as it’s gone very rattle but I expected that until oil circulates. Can this just be a fuel issue or more serious and yes fuel pump belt is ok |
what about the tyre / schrader valve at the back of the engine.
I guess you will just have to part loosen one of the metal pipes to the injectors and confirm you have decent fuel there.
The supply to schrader valve seems ok but I don’t know these engines but flow at injectors seems about the same as schrader valve guess I need to strip and check fuel system |
thank you for the help andy but asking for a bit more where exactly is the cam sensor located and any pictures of the position |
The sensor monitors the cam wheel at front of engine
https://www.ebay.co.uk/itm/353395807688
Ah yes that’s left head then I was talking as from front the one I had problems with is right head is there a sensor there too ? |
No. Only one sensor |
getting a really good flow at schrader valve but cracked a pipe from injector and pressure here doesn’t seem to be any stronger . Fuel pump belt good and turning fine just not much pressure at rails. Engine sounds good turning over and even sounds like trying to fire occasionally. Any likely places to look for leaks on pressure side |
