Home > General > Please help HDC trans fault engine failure
Probably needs a new throttle pedal.
Get a diesel one
Post #616429 Fri Aug 06 2021 1:27pm
The throttle pedal has a pair of potentiometers in the mechanism (it's a drive-by-wire throttle). If one or both has a fault, the system will inhibit HDC and special programs and go in to limp mode:
Quote:
The APP is integral to the accelerator pedal assembly. The APP sensor enables the ECM to determine the throttle position
requested by the driver on the accelerator pedal.
The APP sensor is installed on the pedal box and consists of a twin track potentiometer with wipers driven by a linkage connected
to the accelerator pedal. Each potentiometer track has a 5 volt supply and ground connection from the ECM, and produces a linear
signal voltage to the ECM proportional to the position of the accelerator pedal. The signal voltage from track 1 of the
potentiometer is approximately double that of the signal voltage from track 2.
From the sensor signals, the ECM determines driver demand as a percentage of pedal travel, where 0% is with the pedal released
and 100% is with the pedal fully depressed. Driver demand is then used to calculate throttle angle, fuel quantity and ignition
timing. The ECM also outputs driver demand on the controller area network (CAN) system, for use by the brake and gearbox
control systems.
The ECM stores the signal values that correspond with closed and wide open throttle, and adapts to new values to accommodate
component wear or replacement.
The signals from the APP sensor are monitored by the ECM for short and open circuits and plausibility. If a fault is detected, the
ECM:
Stores a related fault code in memory.
Illuminates the SERVICE ENGINE warning lamp in the instrument pack.
Inhibits the driver demand message on the CAN bus, which disables the Hill Descent Control (HDC) function of the
anti-lock brake system (ABS) modulator and reduces the performance of the automatic gearbox (harsh gear changes and
loss of kick down).
Adopts a throttle limp home mode.
The throttle limp home mode adopted depends on the nature of the fault:
If a fault is detected with one potentiometer track, the ECM limits vehicle acceleration by limiting throttle plate opening.
If a fault is detected with both potentiometer tracks, the ECM uses the throttle plate to run the engine at a fixed speed of
1472 rev/min while the brake pedal is released, and idle speed (750 rev/min) while the brake pedal is pressed or if there
is a brake pedal sensor fault.
If there is a process fault in the ECM, the ECM either uses fuel injection cut-off to limit engine speed to 1300 rev/ min or
disables fuel injection to stop the engine.
Might be a new throttle pedal is required. Might just be a loose wire in the plug. Got to be worth checking the wiring to the pedal in the first instance. 2012 SDV6 - it's missing a couple of cylinders
Post #616430 Fri Aug 06 2021 1:28pm
Jjmorris90
Unplugged and cleaned. Works fine thanks everyone! No faults at last
Post #616432 Fri Aug 06 2021 1:54pm
Remarkable turn around for a car that was going to be broken a few hours ago Laughing
Post #616433 Fri Aug 06 2021 2:01pm
Jjmorris90
Haha tell me about it. Though I spoke too soon! After driving around for half an hour the engine faulty came back. Rescanned and it says throttle sensor again. Does anyone know the part number? Does it have to be from a same engine spec car etc
Post #616434 Fri Aug 06 2021 2:44pm
https://www.ebay.co.uk/itm/164409733540?ep...Sw4ntcRIUA
Post #616435 Fri Aug 06 2021 3:15pm
Jjmorris90
Thanks!
Post #616436 Fri Aug 06 2021 3:43pm
Kot
Top Class fault finding support guys!!
I enjoyed this one lol
Post #616450 Fri Aug 06 2021 8:37pm
Mafya
United Kingdom 2010 Range Rover Sport TDV8 HSE Lux Buckingham Blue
Top forum if you have issues and plenty of knowledgeable members on here…
Post #616455 Fri Aug 06 2021 11:10pm
