![]() | Home > General > Front lower arms replacement |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
You could just go for OEM - basically the same items as LR branded ones but without the added cost of the LR logo on the box. Same maker, different box.
| Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43
This is great advice, thanks.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
I tried a set of the Poly Bushed ones first and didn't like them seemed a little harsh to me personally, so changed them for the Meyle ones, as said personally found them better, absolutely no issues with Meyle one's quality or fit, must have fitted them a couple of years ago now and still fine.
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
Another vote for the Advanced Factors arms, fitted with the Meyle HD bushes |
Worth remembering also that the longevity of replacements will be helped by installing them correctly. I bet a few garages just torque up the bolts with the suspension in full droop. Should be done with the suspension at normal road position. Tightening them up in droop puts the bushes under more stress when the car is sitting normally so they'll fail sooner. 2012 SDV6 - it's missing a couple of cylinders
Thanks for the advice guys, going with the Meyle HD arms |
Just out of interest, if I read a previous post correctly you have only had the vehicle a little over a week so why are you replacing the front arms, if they need replacing so quickly surely the dealer should be paying for this, assuming you bought it from a dealer.
Yep, that's right.
| Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 262
Meyle HD |
| All times are GMT |
