![]() | Home > Technical > Fault codes |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4528 ![]() ![]() ![]() |
You've an issue with the hydraulic pressure in the ARC system. Have you checked the fluid level? |
hoppy89 Member Since: 26 Apr 2016 Location: birmingham Posts: 36 ![]() ![]() ![]() |
hi mikey, yes fluid level is as should be |
