| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > tdv8 front /rear anti roll bar / ace removal for dummies??? |
| dt1968 Member Since: 08 Oct 2020 Location: shropshire Posts: 5    | just before anyone says,,, yes i have seen the kit on ebay to remove the ace system, however at 650 quid its a bit rich... especially if i can find two second hand rollbars, buy new drop links and bushes, that should save quite a few quid to use in the fuel tank   | ||
|  Mon Jul 12 2021 9:27pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Great way to ruin the vehicle. Fitting standard anti roll bars will make it wallowy and rubbish - bear in mind the TDV8 never had standard bars fitted. Even in the dynamic system it has its own "tune" from those on the 2.7TDV6 and the petrol models. The TDV8 is a big heavy lump to resist in roll.
|  Tue Jul 13 2021 8:23am |
| dt1968 Member Since: 08 Oct 2020 Location: shropshire Posts: 5    | Agree to some extent that i could go to an independant and enquire, but even then,, after spending at least a couple of hundered maybe much more, id still be left with a system that is complex, troublesome and known to be the achilles heal of these great vehicles... Personally id rather spend money and eradicate it once and for all, so long as it was safe and cost effective... to that end has anybody had any experience with this, maybe fitted a kit?? https://www.ebay.co.uk/itm/254069282435?_t...OON.R2.TR2 | ||
|  Sun Jul 18 2021 5:39pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Troublesome and known to be an Achilles heel? Utter rot.
|  Sun Jul 18 2021 7:42pm |
| dt1968 Member Since: 08 Oct 2020 Location: shropshire Posts: 5    | thanks for yet another uninformative post... are you speaking from experience??  have you done the swap??? im guessing not.. therefore your input isnt really required is it??   i was clearly asking if anybody had done it,, not your personal view on it..
|  Mon Jul 19 2021 8:47pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | It's been brought up as a solution a couple of times in the 10 years I've been on this forum. And after discussions it was dropped as an idea. But hey, you carry on and bodge the job. And yes, it's a bodge. Land Rover fitted the hydraulic anti roll bars to all TDV8s for a reason. Just like they fitted active engine mounts to the TDV8 and not the TDV6. It's a big lump moving around.
|  Mon Jul 19 2021 9:07pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | I wouldn't like to drive a TDV8 without the ARC system
|  Tue Jul 20 2021 7:13am |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784      | Not wishing to discourage you further, but have you spoken to your insurance company about this modification yet?
|  Tue Jul 20 2021 7:39am |
| MakAtak67 Member Since: 27 Dec 2021 Location: Glasgow Posts: 4      |
 New here. ACE pump has collapsed bearing. Tried the shorter belt to get round ACE pump but way top short. As a temp solution- what do I need to do to bypass the pump? | ||
|  Mon Dec 27 2021 3:41pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | See my replies to your other posting   | ||
|  Mon Dec 27 2021 11:05pm |
| Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 427      |
 The facelifted L320 5L V8 was only available globally without dynamic response. It was however 167kg lighter than the TDV8. I could never understand why the 5L V8 could not be optioned with dymanic response as even the lowliest diesel could. | ||
|  Fri Dec 31 2021 4:56pm |
| ZAX1 Member Since: 09 Apr 2024 Location: Rochdale Posts: 6      |
 I need this too | ||
|  Mon Jun 24 2024 7:59am |
| RICHALO Member Since: 05 Apr 2023 Location: TURKS & CAICOS Posts: 1      | Good Day All
|  Wed Jul 17 2024 5:14pm |
| Posting Rules
 enough money as it is.
