Home > General > Front suspension knocking/sensitive issues.....
MallorcaNick
Spain 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hi all,
Recently the front suspension of my 2011 RRS (TDV6) has been getting worse and worse. The steering feels heavier and it feels strangely sensistive even when cruising on the motorway. Also, when I accelerate or decelerate quickly, I hear or feel a knock.
I'm in Spain and the main dealer is useless (or worse than that actually) and you guys have saved me thousands in the past by offering better suggestions than mechanic here offer (as they don't have a lot of experience with RRs). For example, one mechanic said my turbo had gone but you pointed me in the direction of the manifold. £500 instead of £1,300 or more.
I know the suspension issue is hard to diagnose without actually seeing it but I would be extremely grateful for any tips or hints that I could subtly suggest to the mechanic who did the manifold. Any suggestions re. approximate price for the fix too would be gratefully rec'd.
Thanks all......yet again.
Post #615669 Mon Jul 12 2021 2:55pm
gogsy1956
The first thing that springs to mind given the age of the car,,, and not knowing it's history, is front lower suspension arms. These are a common issue, normally rather than try to fit new bushes the old arms are cut off and new ones fitted,,, saves a lot of time, but 4 wheel alignment must be carried out when this has been done,,,,,,, and it needs to be done by someone with the correct equipment ands knows exactly what they are doing or you will be worse off than you were originally.
The steering might well be a separate issue,,, do a search on here and you will find a few ideas. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #615682 Mon Jul 12 2021 7:01pm
MallorcaNick
Thank you. Again! 🙏🙏🙏
Post #615684 Mon Jul 12 2021 7:45pm
One way to diagnose the lower arm bushes is to drive slowly - around walking pace - and then tap the brakes. You'll hear a knock if the bushes are worn. 2012 SDV6 - it's missing a couple of cylinders
Post #615700 Tue Jul 13 2021 9:11am
MallorcaNick
Great advice. Thank you. I'll give it a try.
It really helps to go to my mechanic not totally blind. All mechanics make mistakes but the levels of errors and incompetence in Spain us off the scale. I hope I've found someone reliable, but even they need a nudge in the right direction (from you guys) sometimes.
Thank you so much.....
Post #615702 Tue Jul 13 2021 9:20am
Oldandconfused
You may also consider checking the lower steering column universal joint. They can become stiff and notchey when turning the steering. I take it you have checked the PS fluid level already.
Post #615705 Tue Jul 13 2021 10:01am
MallorcaNick
I've been quoted £450 for parts, labour and realignment.
Doesn't that seem quite a lot for just changing the bushes???
Post #618592 Mon Nov 01 2021 9:41am
MarcMGD
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Surely they mean changing the entire arm? I don't know of anyone who would change the Bush vs buy a whole new arm? I installed Myle HD arms on my L320 and the parts alone were £300. I expect he is getting you complete arms but just cheaper ones for a £100 each and then £250 to install them?
It's about a 4 hour job if you know what your doing and have a recip saw handy just incase.
Confirm with the mechanic he is changing the whole arms would be my first point of call.
Post #618595 Mon Nov 01 2021 9:50am
MallorcaNick
Quick update: Got the bushes done (although it was about £420!!!) and the car drives so much better. No more knocking noises and it weirdly feels like the power steering is now turned on, if that makes sense.
Thanks to all who helped.....
Post #618955 Tue Nov 09 2021 12:58pm
