![]() | Home > Faults & Fixes > Parking sensor/camera issue |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5141
need to clear the codes, put the car in drive & handbrake off. Back to park.
| Millsy66 Member Since: 10 Jul 2021 Location: Kilmarnock Posts: 4
Cool thanks Andy, i will try & get them cleared then see how i get on with that. Do you reckon it should all work after doing that? |
| Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163
no need to get the codes reset. once the fault is found the problem will reset itself.
No. It won't make it work.
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
I would double check the connectors again, apart from the headlight connector and two other connectors ( white and green I think), which are quite visible and live behind the headlight itself there is another,, no so easy to see which normally hangs in the void below the headlight. It isn't that easy to spot and is quite small compared to the others,,, it is also very easy to push it together the wrong way round as it is circular, you need to look at the male and female parts to see how the pins are aligned before just shoving it together.
Thats great, thanks very much for all the advice…much appreciated. Will give it all a try this week & see how i get on |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
If he didn’t disturb the sensors, did he repaint the bumper with them still installed instead of separating them? 2019 5.0 SC SVA (Current)
The DTCs are incomplete (LR diagnostics would have an additional 2 numbers) but one code suggests individually that there is a short to open, short to power or corrosion damage. Another suggests an internal fault but as the fault is with all 4 at the same time, you either have a common power or Earth issue (check fuse) or I suspect there is possibly too much paint on the cover and/or the paint has bonded the sensor to the bumper (I think they should be free to vibrate slightly). Obviously the DTC doesn’t make reference to painting as it’s not an expected fault.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
As Chris said all those codes have another 2 digits associated with them, as there are four codes with the same first set of number/letters B1B you actualy have a option of 12 fault codes, however they all state the same possible causes, wiring harness or internal fault in sensor, unlikely 4 sensors would fail at the same time, unless as suggested they have excessive paint on them, there is actualy a L/R instruction how to paint the sensors. I think again as suggested I would start with the plug to make sure it is push fully home and no damaged pins.
Yeah it was painted with the sensors still in place, he said the only thing he disconnected was the plug under the drivers headlight (although he forgot to plug it back in).
| Phil5197 Member Since: 25 Apr 2020 Location: Leicestershire Posts: 4
Which fuse is it, can’t see it mentioned in my manual?
Try fuse No.36 passengers compartment fuse box.
| All times are GMT |
