Home > General > 2010 tdv8 air suspension strut replacement
rrsade
I've got rrs 2010 tdv8 with a leaky and squeaky near side front strut, my question is if its easy enough to change over a new strut as been quoted £1000 to change it. Also if anyone knows of a decent supplier for the air strut's
Thanks 👍
Post #615570 Thu Jul 08 2021 9:02pm
knwatkins
Very easy to change. One big bolt at the bottom, 3 little bolts at the top. 30 minute job. Kev
Post #615573 Fri Jul 09 2021 7:59am
If it's got the dynamic dampers they're not cheap and one should replace dampers as an axle pair.
You can do them yourself - there are posts on here and on the Disco3 sister site showing how it's done. Access to the top mount bolts is very tight but otherwise it's deflate the bag, undo top mounts and bottom bolt, undo air line and wiring, replace. Obviously that's simplified but the general idea. As said, have a search and you should find some good write ups. 2012 SDV6 - it's missing a couple of cylinders
Post #615574 Fri Jul 09 2021 8:03am
rrsade
Thanks guys,
I had a look but could not find much on the rrs will check out disco page , has a wire coming out the top so would guess it got the adaptive damping so you recommend changing to two at same time ? The garage quoted me £799+vat + fitting seem steep to me that was for just one .
Cheers .
Post #615576 Fri Jul 09 2021 9:25am
That price per strut is because they come in a pretty box with Land Rover on it, go O.E Aftermarket in a plain box and you will get a pair for that price.
Post #615577 Fri Jul 09 2021 9:47am
knwatkins
If you have the adaptive dampers, it's part number LR052867 you need.
Have a Google around for parts but don't buy cheap Chinese rubbish or Britpart.
LRseries.com currently have BWI struts at £436.66 a piece. That's what I'd go for. Kev
Post #615579 Fri Jul 09 2021 10:21am
Kev, don't know where the struts are actualy made, but although BWI is O.E. BWI is a Chinese company they bought that part of Delphi about 10 years ago, hopefully they are better quality than the usual Chinese stuff though. Laughing
Post #615580 Fri Jul 09 2021 10:41am
knwatkins
Yes, I remember that from when I was looking at them a few months ago Col in case I ever need to replace them on the L405.
What I meant was, try to avoid the unbranded stuff from eBay and Aliexpress etc. Wink Kev
Post #615581 Fri Jul 09 2021 10:50am
DrRob
Use www.advancedfactors.co.uk
Speak to Paul Redding. Forum discount too
Thumbs Up Visitor from fullfatrr.com
Post #615582 Fri Jul 09 2021 10:55am
knwatkins
I was going to suggest that Rob but for the same Advanced are £103.51 more expensive per strut than lrseries.com Shocked Even with the forum discount, that's a hell of a lot more expensive.
LRseries: https://www.lrseries.com/LR052867G-Shock-A...h=Lr052867
Advanced Factors: https://www.advancedfactors.co.uk/lr052867...2263-p.asp Kev
Post #615583 Fri Jul 09 2021 11:30am
rrsade
Thanks for that guys, will go for the bwi ones if the same as original delphi one i got on now,
A question tho if i change them my self will the car need calibrating? Or will it sort it self out ? Cheers.
Post #615584 Fri Jul 09 2021 11:36am
Yes. Dampers should always be changed as an axle pair. If you have a brand new damper on one side and tired old one on the other side, you'll get some potentially unpleasant ride/handling characteristics. And that could lead to an accident. 2012 SDV6 - it's missing a couple of cylinders
Post #615586 Fri Jul 09 2021 2:32pm
knwatkins
^^^^agreed Thumbs Up Kev
Post #615587 Fri Jul 09 2021 3:13pm
Oldandconfused
I was under the impression that the air spring can be separated from the damper and can be replaced individually. I don't know if that is a sensible approach, how much additional work it is involved or how much can be saved. Those struts are bloody expensive.
Post #615588 Fri Jul 09 2021 3:40pm
The damper is the expensive part of the strut. 2012 SDV6 - it's missing a couple of cylinders
Post #615597 Fri Jul 09 2021 11:10pm
