Home > Faults & Fixes > Suspension Noise
Hawk1262
2010 Range Rover Sport Supercharged Santorini Black
Suspension Noise
Hi All
No fault codes come up. Drives as it should, when it's cold or on a short trip it's fine, when the car is hot or on a longer trip you get creeking from front & rear when you go over uneven roads under braking & pulling away. Any clues as to whats going on Question thank you for any help you give
Post #615049 Tue Jun 22 2021 10:42am
Hawk1262
Have now ben told by garage it is the front & rear ARB cost to replace all with the updated bushes is £773.40. Can anone tell me if thats a correct price seems a little high?
Post #615333 Thu Jul 01 2021 7:48am
Oldandconfused
If it's just the ARB's then I would say that's far too much. Genuine LR roll bar bushes are probably way less than £100 and although they are apparently awkward to access (there is a special tool for the front ones to make it easier), I don't see over £650 labour @£50 per hour?
The only issue is if the bolts are really corroded and snap/round off (if cack handed), certainly for the rear ones, the body will have to be raised to get them out.
Another thing to consider is that the the bar also wears and standard LR bushes will become loose very quickly. Poly bushes are a better long term solution, albeit the ride may be slightly harsher. I have poly on the rear of mine and have noticed no difference whatsoever.
Post #615336 Thu Jul 01 2021 8:55am
