Home > Maintenance & Modifications > Air conditioning stopped working
Kit
United Kingdom 2009 Range Rover Sport TDV8 HSE Adriatic Blue
My air conditioning stopped working today but if i'm honest it hasnt been working great for a while, I cant hear any issues from the engine bay.
Are there any checks I can do before I take it in for repairs as I do like to do as much maintainance as I can myself?
Post #615106 Wed Jun 23 2021 9:40pm
gogsy1956
Good chance if it hasn't been working right for a while,,ie, not cooling down properly, is that you have a slow leak and it has finally got to the stage where there is no gas left in the system. Quite common for the condenser to get damaged as it's open to the elements, get on your hands and knees and look through the lower part of the grill and see if you can spot any damp patches,,, or look under the front bumper. The condenser sits in front of the engine radiator. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #615107 Wed Jun 23 2021 9:52pm
Kit
Thanks for the quick reply, i'll have a look in the morning to see if I can find any damage Thumbs Up
Post #615108 Wed Jun 23 2021 9:56pm
gogsy1956
physical damage is not always apparent, a leaking condenser will leave a trail of refrigerant,, a thin oily stain, but a very slow leak might not be as obvious. There are O rings in the pipe connection in the engine bay,,, down the right hand side of the radiator,, 2 small pipes on a manifold. Not much else on the system,, the compressor is quite robust and lives right under the engine. I have recently changed the condenser on mine as I had problems. Best option might be to get some gas into it,, see if it works and keep an eyesore leaks. There are a couple of pics in my gallery. 2010 RRS, TDV8
22" overfinch
Post #615109 Wed Jun 23 2021 10:13pm
Kit
Thanks for the tips, if the condensor and O rings look good, is this a good price for a regas? https://autoregasac.wixsite.com/mysite/services
Guessing the RRS will be 800g which is £99?
Post #615110 Wed Jun 23 2021 10:37pm
Heremyjill
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hope that it is not the condenser unit.
To replace the unit is a total removal of the front end of the car. Labour time in excess of 5 hours and the parts and gas on top of that.
Not a cheap job.........I know as I am about to have it done!! "Every Day is a School Day"
Now 2014MY RRS SDV6 AB
Now 2018MY Ford Fiesta ST Line 140bhp
Gone 2006MY BMW X5 3.0d Le Mans
Gone 2001MY BMW 530d Estate
Post #615113 Thu Jun 24 2021 10:16am
gogsy1956
Easiest option is to get a mobile AC guy out,, I got someone to come to the house, £70 I think it cost,, or you can always visit a specialist if you have the time. If you drop some gas in you will see within a day or so if you have a leak. I did mine last year, got a Nissens condenser for less than £80, it's more fiddly than difficult to change,,,, front grill, lights and bumper off, slam panel to move forward and a couple of other bits just to make life easier. If you know what your doing its possible in 3 or 4 hours. Got the mobile guy back to recharge the system and he only charged £20 for his gas. 2010 RRS, TDV8
22" overfinch
Post #615125 Thu Jun 24 2021 4:49pm
adriansj
Good evening,
I had my system nitrogen tested and result is my condenser is corroded at bottom so I have bought a replacement. I had seen instructions on another forum which said it was 2 hours and all looked very easy 8 bolts on each side and lights and front grill off so I compared my 2008 TDV8 and to my dismay it's totally different. Now does anyone have a complete process in order of what to remove and any pictures would be great otherwise I'm paying local specialist £270+VAT to fit the new one which includes the gas.
Cheers,
Adrian
Post #615132 Thu Jun 24 2021 8:45pm
gogsy1956
Adrian, I think 2 hours is a little ambitious,, I looked at a couple of videos before doing mine but found that they referred to disco's or full fats,, I'm sure the V8 has an extra radiator which makes life difficult. I don't think the price you got is too bad considering it includes gas as long as it's fixed and not an estimate. I had plenty of time to do mine so didn't really rush, some bits I had to fathom out but now I know how it all goes together I could do it reasonably quickly.
If you are still determined to do it yourself I could put together the pictures I took and add an explanation To go with it,,, but you would have to give me a day or two to put things together,,,,, this is one of the reasons I've not posted a "how to" on the forum,, never seem to have 5 mins these days. 2010 RRS, TDV8
22" overfinch
Post #615165 Fri Jun 25 2021 7:47pm
adriansj
To be honest I wussed out and decided to pay the specialist the cash having also realised that the V8 is a lot more extra work. I can't risk a half finished job and also think the 270 plus vat is reasonable.
Thanks for coming back though. Now on to fix my gps antenna, bloody car is costing a small fortune 😂
Cheers,
Adrian
Post #615169 Fri Jun 25 2021 9:43pm
gogsy1956
The price you had was quite reasonable so not much to complain about.
Do a search on here for " shark fin aerial ",,,, you will find lots of fixes. 2010 RRS, TDV8
22" overfinch
Post #615187 Sat Jun 26 2021 6:29pm
Kit
I've got a guy coming to regas it on Wednesday, the condenser looks fine, so hopefully it's an easy fix Thumbs Up
Post #615198 Sat Jun 26 2021 11:23pm
Stevepd
Cheers,
Adrian
Here you go ref GPS
https://www.rrsport.co.uk/forum/topic32826.html 2006 2.7 TDV6 HSE in Cairns Blue.
Post #615199 Sun Jun 27 2021 6:22am
gogsy1956
Don't forget to post your results Thumbs Up 2010 RRS, TDV8
22" overfinch
Post #615200 Sun Jun 27 2021 9:08am
Kit
Just a final update, I got the system refilled and it had 115g of gas still in it. He leak tested it and didn't find anything amiss, which was a relief! Although he did put 5g of UV dye in the system just incase there is a slow leak somewhere.
The AC is back to ice cold again, ready for the rest of summer Thumbs Up
Post #615461 Mon Jul 05 2021 5:13pm
