![]() | Home > Technical > Restricted Performance & engine light |
| Hawk1262 Member Since: 22 Jun 2021 Location: Bristol Posts: 17
Have done all of that, Now going into garage to be checked out not sending it to the dealer as can't be trusted. Will update when garage give a report. |
It’s now back from the garage it was an injector on cylinder 2 current out of spec & low resistance, had the injector replaced total cost £486.42 including diagnostic, running a lot better now with no faults coming up at all. It is going back into the garage on the 19th to carry out a walnut blast to remove carbon build up on the intake valves & to have the other 7 injectors bench tested, as the car has done 182k miles that should sort it out for a few years. The biggest cost of this is the labour as the supercharger has to be removed. Also at the same time having the front & rear ARB bushes replaced with the updated bushes & brackets, this sould stop the creaking. |
| All times are GMT |
