Home > In Car Electronics > phone wiring
So if you have connected the optical orange fibre and power to box and the music still plays out speakers then you have connected it correctly.
Set your phone to search for Bluetooth and connect.
I think the code is 2121
I think there are several ccf settings. I think you need to say you have a cradle fitted (even if you haven’t )
Post #614917 Fri Jun 18 2021 10:42pm
jk3528
Ok will try. do I need the steering wheel controls?
Post #614918 Fri Jun 18 2021 11:05pm
You should be able to use the lcd display
Post #614919 Fri Jun 18 2021 11:50pm
jk3528
So now it works and I don’t have to pair it all the time
Post #614956 Sun Jun 20 2021 11:25am
Just needed pairing ?
Where did you power the BT from ?
Post #614974 Mon Jun 21 2021 7:52am
jk3528
I’ve put it behind the amp and taken the power off the rear outlet
Post #615058 Tue Jun 22 2021 6:22pm
