Home > Maintenance & Modifications > Today’s job is 😬
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Today’s job is 😬
V8 brake upgrade and near side front output shaft seal. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #614805 Wed Jun 16 2021 8:44am
Stevepd
Good luck. The brake upgrade is like night and day, you won’t look back. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #614824 Wed Jun 16 2021 6:44pm
Devon Z
Well I got the seal and the fronts done, took me an age to get the brake hose retaining bracket bolt out!! Then the callipers were in a worse state than I thought so took longer to clean up, I was going to paint them silver to match the new brackets but ended up giving then a coat of Matt Black for now as I could blend it into the rust better.
The old discs were in a bit of a state.
And now.
Hopefully we’ll get a dry day soon to do the rears? Thunder storms on the way. Steve
Post #614825 Wed Jun 16 2021 7:03pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Good job Thumbs Up I’m going to replace my front disks next month or so just finished replacing front and rear diff oil,Had my gearbox transfer box done about 4 months ago so just want to finish it off with the diffs.
Post #614826 Wed Jun 16 2021 7:19pm
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Nice. Is this just a case of calipers and disks or do you need new carriers?
Post #614828 Wed Jun 16 2021 8:05pm
Devon Z
New caliper brackets required for the larger discs, same for the rears. Steve
Post #614831 Wed Jun 16 2021 8:54pm
Devon Z
Hope you have better luck than me with the diff oil? Rear offside output shaft seal started leaking after I did mine, then the front offside started leaking and I’ve just done the near side front, mind you breather filter was blocked on the the front diff, getting quite good at draining and refilling the front diff. Steve
Post #614832 Wed Jun 16 2021 9:05pm
Bertbuckie
Cheers Devon. I dont even know what size mine are but I did a volvo s89 with xc90 brakes and it made a hellish difference. Be interested to see how this pans out Smile
Post #614835 Wed Jun 16 2021 10:07pm
Devon Z
I’ll let you know how it performs.
Mine were 317mm, these are 337mm the largest disc size for standard callipers, next stage requires Brembo callipers. Steve
Post #614836 Wed Jun 16 2021 10:26pm
Bertbuckie
What size wheels are over them?
Any difference in pots or is it all single?
Sorry for all the questions, too many people go for speed and forget about other components, its nice to see this being done Smile
Post #614838 Thu Jun 17 2021 8:02am
Devon Z
No problem mate. I’m running the standard 19” wheels the V8 conversion requires minimum of 18” I believe? So it’s the small hands sinario 😆
You reuse the original callipers which are two piston on the front not sure on rears haven’t done them yet.
I know what you mean, it’s a very heavy machine to stop 😳 first time I tried to stop from 70 on the local ring road was a bit butt clenching😳 I thought then I needed to reset my braking distances for this vehicle.
My Volvo is 1.5 ton and 300bhp and stopped very well on 302mm single piston fronts. Steve
Post #614839 Thu Jun 17 2021 8:27am
Bertbuckie
Yeah I noticed mines a bit worrying to slow down when tanking on.... Mine also appears to have warped fronts ( odd as the garage put them on just before we picked it up ) so I may look for an upgrade but I dont yet know the size of mine. I am on 20's atm but I have been looking at 22's so clearance shouldnt be an issue.
What ovlov do you have? Lovely motors they are, the s80 was the second best car ( the RRS being best ) we have had. A mate of mine is orgonising some record breaker for volvos soon, 600 of them on a track or something.
Post #614840 Thu Jun 17 2021 8:41am
You could always go for the six pot Brembos with 380mm discs, same as the S/C, Powerful UK do a conversion kit for about 1K or used to.
Post #614841 Thu Jun 17 2021 9:15am
For a given speed, your RRS will be carrying 40% more kinetic energy than your Volvo irrespective of engine power.
I think it's also worth remembering that LR will have to consider how the brakes work in hot climates, silly-cold conditions, when off road (using the brakes in traction control to control wheel spin), giving the "chauffeur braking feel", etc., and design the brakes to deal with it all. For the standard RRS models, having ultimate braking bite on the motorway was probably not at the top of their list. I found an Evoque I had on loan once had excellent brakes with real bite so LR can do it, but the Evoque will have different design priorities to the RRS.
My old TDV8 had the 4-pot Brembos as standard and even that didn't feel as good on the brakes as our old Skoda Octavia. It never made me think "I'm not going to stop" but it never had the top of pedal bite that a lot of ordinary cars have. Don't get me wrong, I could chuck that down a fast road and give the brakes some serious welly and they never let me down. But they never had confidence-inspiring bite on the pedal. I just learned to drive around it and accept it. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #614842 Thu Jun 17 2021 9:15am
They still do, Col. Thumbs Up
https://www.powerfuluk.com/vehicles/range-...ipers.html
Needs 20 inch rims, however, to fit over them. 2012 SDV6 - it's missing a couple of cylinders
Post #614843 Thu Jun 17 2021 9:19am
