Home > General (L494) > Rear Diff Pinion seal slight leak
rr888
Hello Guys,
Im looking to replace the rear differential pinion seal. Is this something that can be done relatively easily ? Has anyone experience in this ?
Can i remove the main drive axle and replace the seal. I know i may need a special tool
Any info help would be much appriciated
I have a 2014 RR sport
Post #614748 Mon Jun 14 2021 10:42am
Google SSM72080 not uncommon problem, contains info. regarding fault and available seal repair kits.
Post #614749 Mon Jun 14 2021 11:03am
gtr_skyline
This is a known warranty issue - not sure if you can chance your luck with LR and see if they could do a "goodwill" discount.
Prashan MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian
Post #614750 Mon Jun 14 2021 11:16am
rr888
Ok great thanks guys, i was also after some info ref changing the seal itself ? at Home
Post #614752 Mon Jun 14 2021 12:07pm
This might help, but may have been re-issued by now, does look like few special tools could be needed.
https://drive.google.com/file/d/13MVicp3-g...sp=sharing
Post #614753 Mon Jun 14 2021 12:40pm
