Home > Technical > brake light failure |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
Time to start checking the wiring for damage, not sure which way the wiring loom runs,, thinking it might be along the bottom of the door area then up into the boot area. 2010 RRS, TDV8
Mon Jun 07 2021 11:29am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4858 |
Did you actualy check for a feed in the vehicle harness with a multi-meter before replacing the the whole lamp? green and purple wire if I remember right.
Mon Jun 07 2021 11:52am |
MK stylee Member Since: 25 Nov 2020 Location: Devon go Posts: 3 |
Green and purple
Mon Jun 07 2021 4:47pm |
UPDATE!
Mon Jun 21 2021 7:15am |
